show ip-security dhcp-snooping information-option
Description
Displays the DHCP relay agent option (option 82) settings.
Syntax Description
Default
N/A.
Usage Guidelines
This command displays DHCP relay agent option (option 82) settings. For example, the following command:
Generates the following output:
 Information option insertion: Enabled Information option checking : Disabled Information option policy : Drop
The following command:
 Information option insertion: Enabled Information option checking : Enabled Information option policy : Keep
Platform Availability
